Old 04-27-2024   #1
scorp508
Cool Dyno rip of 1994 #150
I attended Slowhawk Performance's (Bridgewater, MA) annual open house this morning and let 1994 #150 sing on the Mustang Dyno. She pulled to 7k and the curve hadn't quite tipped over when we let off. I was honestly expecting some heartbreaking figures from the Mustang Dyno as I know they can read a little lower, but the figures were right in line with what previous owners hit.
Peaked at 445 RWHP @ 7K and 392 lb. ft.
Both vids uploaded in 4K 60 FPS if you need/want to adjust your YouTube quality settings to see them like that.
Run 1:https://youtu.be/H6PyzYl_LlE
Run 2: https://youtu.be/leVBTCJUGrc
I have to say a lot of attendees were shocked to see what they thought was "Just a C4" made the sounds and power she did. It was my first car event with her and got many compliments and many questions on the ZR-1 platform. It was the first time many people had seen one in person.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
Old 04-27-2024   #2
efnfast
Default Re: Dyno rip of 1994 #150
That's my favorite song, listening to these things sing on the dyno.
Old 04-27-2024   #3
grahambehan
Just an FYI. I would say the car detonated around 25-26 seconds on run 1 and around 17-18 seconds on run 2.
Graham
grahambehan is offline   Reply With Quote
Old 04-27-2024   #4
scorp508
Thumbs up Re: Dyno rip of 1994 #150
Graham
Thanks Graham! My ALDL -> USB cable didn?t arrive yesterday like it was supposed to, so unfortunately no data from today. The AFR stayed clean from the shop?s sensor at least. I believe the plug wires are new-ish but not sure on the plugs. Once I can datalog I?ll do some highway pulls and check for knock counts.
Old 04-28-2024   #5
Graham,
Was it the puffs of smoke that gave it away for knock? My experience is that if there is detonation it likely occurs between 4500-5500rpm on a WOT pull.
Old 04-28-2024   #6
grahambehan
Graham,
Yes. The engine is most "Knock limited " around peak torque typically.
Graham
Old 04-28-2024   #7
tiegsd
tiegsd's Avatar
Cool vids. And I learned a little something too. Thanks for the post!
1990 Black/Black ZR-1 #1155
1993 White/Red coupe (Regrettably sold)
tiegsd is offline   Reply With Quote
Tags
dyno
