![]() Join Date: Sep 2013
What are the options on sensor replacements? I just replaced tires and the shop that put tires on before did not line up sensor with decal on rims and also put them right at the edge of the rim. The tire shop hit them when they broke down the bead and they shattered. Rear wheels were fine. Thanks!
![]() Join Date: Aug 2006
If you want to keep stock system, EBay probably is the best bet. Sensors are specific to each corner I think.
I have looked there but was wanting to try to find some magic stash that had new. Looks like I don't have an option except for used. Yes, they are color coded for each wheel location. Thank you! Don
![]() Join Date: Sep 2008
After a genius at Costco broke one two years ago when replacing the tires, I (Costco) bought a NOS on eBay. Didn?t work. Ended up duct taping the one they broke to the clamp - used the good stuff you can?t tear by hand. Works fine.
You do not necessarily need the exact color sensor. I recall an article posted by the National Corvette Restorers Society that outlined how to adapt any sensor to function to at the wheel position where it is needed. If I find a link I'll post it.
David |
#6 | |
![]() Join Date: Dec 2003
![]() Join Date: Oct 2019
There was at one time, someone remaking the stickers for these that go on the outside of the wheel. Does anyone know who that was, or who might have some? Thanks!
1995 ZR-1 #004 - Yellow/Black 1996 LT4 #3828 - Yellow/Beige/LT4/Z51 - 1 of 4 |
![]() Join Date: Dec 2005
The stickers are different for different MYs I have some for the 1990 MY if you are looking for 1990.
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
#9 | |
Mike
#10 |
Check with Corvette Central or Ecklers. If memory serves I think they may have the later MY stickers.
