Tachometer on 1990 ZR1 quits once in a while when driving.
Needle drops as if ignition key is turned off to less than zero. If I turn the ignition key on (engine off) the tachometer needle does not go up to zero like normal indicating a bad connection. Seems like a bad connector on instrument cluster since the tachometer function often returns to normal zero when ignition key is turned on and tachometer will then function normally for a while.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-25-2024 at 12:43 AM. |
![]() Join Date: Jul 2004
I had a crazy tach needle it was reading about half what It should have. decided to get the Batee chip and fixed it.
But you could for sure have some weak solder joints
