02-24-2024 | #1 |
Knock Sensor 1995 ZR1
Hi anyone here that can offer me help or suggestion
1995 ZR1 not sure when it happen my wire clip broke wire fell and burn on my header pipes causing my service soon lite to come on. I do not have a tech 1 scanner so I used a jumper. I forget the code number by came up knock sensor. I purchase a new knock sensor and sensor wire. I cut out the burn wire replace with new wire and sensor. I cleared the code getting C12. After starting the car the same knock senor code would reappear in about 15 second. I then purchase a AC DELCO senor with wire installing and clearing code. Start the car and getting the same code just after starting. any suggestion will be great I,m in the Wash DC area If know of a good ZR1 shop in this area let me know |
02-24-2024 | #2 |
Re: Knock Sensor 1995 ZR1
I had a knock sensor code on my 1993 when I purchased it last year. No burned connector like you. I replaced the knock sensor with an AC Delco unit I got from Jerry?s and problem solved. One check I did before changing the sensor was to check the continuity of the wire from the knock sensor connector to the ECM plug. Maybe check that to make sure your wire/connector are good, easy to do, check the service manual for the terminal on the ECM plug, I do not currently recall which one it is. Good luck,
Brian |
02-26-2024 | #3 | |
02-26-2024 | #4 |
I'm in Fairfax, VA and would be glad to help you out. If you are not in a hurry recommend joining us at the next WAZOO maintenance day event which we have from time to time.
02-26-2024 | #5 |
Interestingly, when I had my 94 on Jim?s lift about 10 years ago, we found knock sensor wire was burnt and broken off but check engine light never triggered. Soldered the wire together and no issue.
02-26-2024 | #6 | |
03-09-2024 | #7 |
I like to thank you all for the suggestion and help concerning knock sensor and code. As one reply I'm going to purchase a knock sensor from Jerry. One thing I failed to mention after connecting my new lead wire I turn ignition on without starting use my test light at lead received on power.
