Old 12-31-2023   #1
rosseich
Question Oil Filter Question
I have three ACDelco PF970 (no C) filters (blue). They are new, in the box and in good shape. They must be 20+ years old. Any issues in using them?
Thanks.
rosseich is offline   Reply With Quote
Old 12-31-2023   #2
secondchance
Default Re: Oil Filter Question
I think you would be fine.
Old 12-31-2023   #3
The oil flows through the outside first ( the small holes ) & back out through the centre hole......
Check for any corrosion and especially look into the center hole with flashlight and see if anything is loose that would flow into the engine. If the box is tight and no corrosion.....I concur with secondchance
Old 01-05-2024   #4
Starman
Starman's Avatar
BTW - these are currently on clearance at Rockauto.
Starman is offline   Reply With Quote
Old 01-05-2024   #5
Starman
Starman's Avatar
PF-970C $5.14 ea
