08-31-2023 | #1 |
LT5 engine spec trim plate
I just got this back from a print shop showing my LT5 engine specs on my
ash tray lid. |
08-31-2023 | #2 |
Re: LT5 engine spec trim plate
08-31-2023 | #3 |
Well first you have to one or fine one. they come up for sale once in awhile.
almost any print shop can make a delcal over the stock lettering. as you can see mine is a little worn. 350 cubic inches 375 horse power 370 torque ft. lbs 11.1 comp ratio Hope you can fine one, or take a picture of the label and add your own information, they may able to duplicate the orginial LT5 emblem. JOHN |
08-31-2023 | #4 |
I have one on my cup holder cover. I might just take the whole thing into a sign shop. I will bring my Dyno Sheet to get my specs. I would also want to cover the 5.7 liter. I always refer to my 368 as a 6.0 liter. Thanks for pointing me in the right direction.
Sent from my SM-A546U using ZR-1 Net Registry mobile app |
08-31-2023 | #5 |
You know I forgot about the 5.7 liter. 368 convertered to liters is 6.03 liter.
mabe they can make a small delcal that says 6.0 liter. over the 5.7 numbers. I should think more about what I do and plan ahead! Ill let you know how I make out. JOHN |
09-01-2023 | #6 |
Went back to print shop and he said he could change 5.7 to 6.0 decal. He
also said that if you can get a full size photo of the LT5 engine spec trim piece any print shop could make a same size decal with your engine specs. I know of a few Corvette sites sell the one for LT1 specs,same size as the LT5 piece. JOHN |
09-01-2023 | #7 |
I went to Corvette central site and they have engine specs trim plaques for
the LT4 and L98 ,you could use that to make your custom LT5 engine specs. Then take it to a print shop and have them make it the away you want. Hope this helps JOHN |
09-01-2023 | #8 |
If anyone is on Facebook, this guy sells a version that you can customize to order.
