Old 06-11-2007   #1
LeoLily
LeoLily's Avatar
Default ID/OD of oil cooler hoses?
Can anyone tell me the ID/OD of the original oil cooler hoses? We think we found a place to get the hoses replaced and crimped (technical term for that also, please?) but they need the specs for the hoses. Thanks in advance! (and yes, I DID check the manual )
LeoLily is offline   Reply With Quote
Old 06-12-2007   #2
SharkPilot
SharkPilot's Avatar
Default Re: ID/OD of oil cooler hoses?
I just replaced mine with steel braid. The originals are at home in my garage. We pulled one of them off of the tubing at the cooler end so I will be able to measure both diameters of the hose.
It will be 9:00-10:00 PM before I get home tonight but will try to remember to get the measurements then.
'til later,
SharkPilot
SharkPilot is offline   Reply With Quote
Old 06-13-2007   #3
LeoLily
LeoLily's Avatar
Thanks!
Old 06-14-2007   #4
SharkPilot
SharkPilot's Avatar
Okay, I was finally able to get out there and take a look.
The ID looks to be about 0.6" and the OD is 0.925". Since the hose is molded the OD varies a bit from .925 to .950.
Let me know if you need a photo of the end view of the cut hose. I can snap one and attach it here.
Hope this helps,
Old 06-15-2007   #5
LeoLily
LeoLily's Avatar
Thanks so much! We should be "up and running" in no time, now!!
Old 06-15-2007   #6
tf95ZR1
tf95ZR1's Avatar
Maybe a dumb question, but don't you have the old oil cooler hose?
When my high pressure power steering hose blew (in the middle of the dessert!)
I just brought in the old hose to a hose fabricator, they re-attached both end fittings to a new braided hose. And $45 vrs. something like $350 new from GM.
Good LucK!
Old 06-16-2007   #7
LeoLily
LeoLily's Avatar
Yep, we do have the old hose - it's still on the car. We are trying to get as much info as possible per the request of our local hydraulic repair shop. They asked, we had no idea so I posted it here
