Old 07-29-2023   #1
Zrracer
Default Pressurizing oil procedure ?
My car has been sitting for awhile. I would like to do this prior to starting. Can
Someone point me to instructions for this?
TIA,
Robin
Zrracer is offline   Reply With Quote
Old 07-29-2023   #2
bob@tradeshowconsulting.c
Default Re: Pressurizing oil procedure ?
what I do on my 1993 ZR1 is remove the fuel pumps fuses ( # 14 and # 15 )
Crank the engine about 3 times ..only cranking for 3 seconds each time ..as to not overheat the starter ....... then I put the fuses in and start the car.
works every time and no chain tension-er noise either.
Now..this might not be right ....and others may not do it this way..and may have another way
but it has worked for me for years
bob@tradeshowconsulting.c is offline   Reply With Quote
Old 07-29-2023   #3
Mystic ZR-1
Mystic ZR-1's Avatar
Remove injector 1 and 2 fuses
Disables fuel injectors
Old 07-29-2023   #4
I believe Marc Haibeck has a tutorial on his website...
http://www.zr1specialist.com/HAT%20W...ping%20LT5.pdf
Old 07-30-2023   #5
https://fuse-box.info/chevrolet/chev...993-1996-fuses
Old 08-07-2023   #6
Rick Gibbons
I don't know if this will help or not, but I enjoy the videos C&S posts and this is one I saw a while back that you might be interested in.
https://www.youtube.com/watch?v=TQgYU0EoZFc
The comments section has multiple posts from several folks who have used this successfully to pre-lubricate an engine after it's been sitting for some time.
Rick Gibbons is offline   Reply With Quote
Old 08-07-2023   #7
Corvettes White
I saw the video some time ago. Figured it started with the story of a lady putting her feet on the clutch and gas petal at the same time to start the car at the factory.
George.
Corvettes White is offline   Reply With Quote
