Old 07-26-2023   #1
richarde
Default Air Con Pressure Cycling Switch 10007057
I am trying to locate an air con pressure cycling switch, GM 10007057, AC Delco 15-2352. I am having trouble finding anyone who stocks it and was wondering if someone in the Registry might be able to point me in the right direction? I've tried Rockauto, Ecklers etc but no joy.
Does anyone know if there is an alternative switch that is available that would do the job?
I live in the UK, which does complicate the issue due to postage.
Thanks in anticipation!
Richard
Richard
1990, numbers 1821 and 2391
1821 - owned since Nov 2002, charcoal / Gray, Stainless headers, B&B system, 4.10's
2391 - owned since Jan 2019, Black / Black, have completed restoration. Jeal headers, Corsa system, 4.10's, Aluminum flywheel with Carolina clutch.
richarde is offline   Reply With Quote
Old 07-26-2023   #2
geezer
Default Re: Air Con Pressure Cycling Switch 10007057
Some Available on E bay!
geezer is offline   Reply With Quote
Old 07-27-2023   #3
richarde
Thanks! The only one on ebay.com is $90 for a used switch. I was hoping to find a new switch as I don't want to risk having to de-gas and re-gas the system twice if I find the 'new' used switch faulty. The urgency has now gone as I now know what I need and can use the car in the meantime.
Richard
Old 07-27-2023   #4
richarde
Sorry!! I got the part number wrong so I no longer need switch 10007057. The part I need is 3041409, which I'll order from Rockauto.
Richard
Old 07-27-2023   #5
Corvettes White
You might try Keath at Eurovettes.com. He splits his time between the US and UK.
Corvettes White is offline   Reply With Quote
