Old 06-27-2023   #1
rufcar
Default Speedo light on start up immediately goes out? 1990
I only have my car about 2 months now and I have repaired everything that was not correct or that bother me. I notice that on start up in my garage the speedo light come on for a few seconds and goes out. Once I drive out of the garage into day light it goes back on! Shouldn't it be on all the time when the engine is running?
I also notice that now that I re-grounded both frame sensors the dash lights are a bit brighter and no longer blink!
rufcar is offline   Reply With Quote
Old 06-28-2023   #2
Default Re: Speedo light on start up immediately goes out?
What year car?
Old 06-29-2023   #3
rufcar
Thought I typed that 1990 zr1 sorry
Old 06-29-2023   #4
I believe the dark LCD is normal on a 1990 LCD.. 1991-newer they changed how the backlighting works. I ended up swapping in a 1991 CCM to get the brighter backlight.
Marc Haibeck has another solution to the backlight for the 1990 as well
Old 06-29-2023   #5
rufcar
Tkx I will look into both. J
Old 06-29-2023   #6
rufcar
Spoke to Marc Haibeck today. Tells me its a common problem with the 90s. He wires in a diode in the line to lift the amount of dimming for in garage and tunnel driving . Or do-nothing since those are the only times it's dim. Jim
