![]() Join Date: Jan 2021
So far my Z runs and idles as silk. But there is some heavy stumbling / hesitation during the transition from idle up into higher revs.
I can feel it slightly when I just rev her up. But with a gear engaged the effect is pretty strong. Let's say I let her crawl in first gear idle and then push the throttle (no matter if carefully or flooring it) the transition out of idle has no power and the beast stumbles. North of 1000 revs she runs great, idle is smooth as well. Any ideas?
ZR-1 #638/1991 |
![]() Join Date: Jul 2015
Hi Matt, with my car in last 2015 I had similar symptoms. My problem was with two coils with intermitent failure and two spark wires... I don't know if this can help you...
![]() ![]() #2342 - Black/Black - March 1.990 - OBX Headers and OBX complete Exhaust Line (No Cats). K&N Air Filter with open Air Box. Jerry's Gaskets Silicone Air Duct. DeWitts Two Row Pro Series Radiator. Samco's Hose Coolant Kit. ECM/EPROM Improved. MSD Spark Plug Wires 8,5mm Super Conductor. EBC Brakes YellowStuff with EBC D-Series Rotors and Raybestos hoses. |
You should check TPS for dead spot.
![]() Join Date: Jul 2004
How much has this car been driven and has it seen 7K rpm shifts lately
Might need a Italian tune up
Thanks, I will go through all those points.
I drove her rather hard recently, with coasting sections as well es full throttle accelerations north of 6k. But in general I drive my Z about 20-30 times a year only with an average of 50 miles per ride. And given my local roads the majority is relaxed back country road driving whereas I take care for WOT accelerations and secondaries engagement as often as possible. Secondaries operation is monitored by my secondary indicator lamp ![]() My guts say it's a sensor or something similar. Just not sure how much my guts know about LT5 engines...
ZR-1 #638/1991 |
![]() Join Date: Oct 2012
Measure out Matthias: the TPS signal must be at 0.50 volts at idle with the oem software on the memcal? Haibeck recommends 0.53 V with his chips. Other voltages can cause your problem.
[SIGPIC][/SIGPIC]Best thing in life is a ZR-1 ride ![]() |
