Old 06-12-2023   #1
Flyman 27
Flyman 27's Avatar
Default Fuel Sending Unit Chassis side pigtail, Impossible to find!
As many of you know, I sell upgraded single fuel pump systems for our ZR-1's. I occasionally received requests for the chassis side electrical connector due to corrosion issues.
THAT WAS A CHALLENGE!
After a LOT of time researching (almost 10 hours!), I finally discovered the GM part number for the connector. It's a Weather Pack 4-pin, but has different alignment tabs so it only fits a Corvette Fuel System.
I even located a company in Germany that had an old stash of them. So I ended up with a couple dozzen of them to offer to anyone who is in need.
I made pigtails with proper color coding of 12" wires.
**If you want I could ship you a custom set with just all the electrical pieces if you want to directly connect to your harness & you have the proper crimper tool. Just send me a note when purchasing.
Here is the ad:
NEW Fuel Pump Sending Unit Pigtail CHASSIS SIDE (NOT Pump Side!)! 1989-95 Corvette LT5 ONLY.
NEW! GM Connector, very hard to find, had to get these from Germany!
Terminals rated at 20 Amp.
12 inch, 16 gage wire leads.
https://www.ebay.com/itm/166109066247
Pics are in ebay ad.
Thanks, Dan
[SIGPIC][/SIGPIC]
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 06-14-2023   #2
AndrewL
Default Re: Fuel Sending Unit Chassis side pigtail, Impossible to find!
Just a post to vouch for the quality and prompt postage of these pigtails, I bought one of these off Dan off ebay recently as a spare.
AndrewL is offline   Reply With Quote
