06-08-2007 | #1 |
Fuel Regulator
I think my fuel regulator which is located at the rear of the plenum is bad. I removed the vacuum line to it today and forgot to put it back, then started the car and drove down the block. The car didn't run very well due to the vacuum leak, but I thought that with out the plenum vacuum the regulator should'nt let any fuel pass at all. So if this is the case... is it possible that it is not opening enough during high demand? Or is this just an open or closed type device with no actual regulation properties?
06-08-2007 | #2 |
Re: Fuel Regulator
no actually you can plug off the vacuum part and get 4lbs increase in pressure . its an old lt1 trick . nothing is wrong with it at all just hook it up and go . or id she running bad?
06-09-2007 | #3 | |
Re: Fuel Regulator
Tyler
55 Polo White (Project) 61 Jewel Blue (Sold to buy above) 66 Nassau Blue 68 Torch Red 88 ZR1 Blue 90 ZR1 White |
06-09-2007 | #4 |
Re: Fuel Regulator
Thanks Tyler. This vacuum line is visible from the top of the plenum and the device it connects to has fuel lines running throught it. It is black and round with a small 1/8 tube connector on the top of it. A year or so ago I did some engine work and forgot to reinstall this vacuum line then too, and the engine would not fire at all.
06-09-2007 | #5 |
Re: Fuel Regulator
The car runs fine with it all hooked up. I'm just trying to figure out if the car should fire up at all if this device controls fuel delivery.
06-09-2007 | #6 |
Re: Fuel Regulator
Yep, that is the fuel regulator.
06-09-2007 | #7 |
Re: Fuel Regulator
Thanks Carter. So the engine shouldn't have fired with the vacuum hose removed...right?
06-09-2007 | #8 |
Re: Fuel Regulator
Can't tell you for sure but I do know 100% that the unit is the fuel pressure regulator. Sorry I do not have an answer on the starting part
06-09-2007 | #9 |
Re: Fuel Regulator
The vacuum line you pulled off actually raises FP when disconnected because the regulator vacuum port is now at 100% MAP. If anything you're running rich which shouldn't harm the motor. ECM will be pulling fuel out trying to get back to stoich.
06-09-2007 | #10 |
Re: Fuel Regulator
the car should start with the vacuum hose unplugged. but I dont know why yours didnt/doesnt?
