Old 05-01-2023   #1
billkirchhofer
Default LT5 Engine & Components for Sale
Have many LT5 engine components and several engines for sale. the list is too long for one post. If you are interested in or need another specific part, contact me. if may take time to respond depending on the number of requests received. Pic are available for all items, shipping not included in price, local pickup (Louisville, KY) preferred for larger/heavier items.
90-92 Crankshaft, main & rod journals are standard, pick #1 $750.
90-92 New oil pump assembly (2 bolt), pic#2 & 3: SOLD
New oil pump housing available without gears/pressure relief valve, pic #4: /$100
93-95 New oil pump assembly (4 bolt) pic #5: SOLD
New oil pump housing available without gears/pressure relief valve:$100
90-95 PN 1006-7512 carbon seal assembly for oil pump: $100
Used 90 LH & RH heads with valves, springs, retainers: $1,500
32 (Complete Set) New Titanium valve retainers: $425
New GM 94 MY 405 HP/4 bolt create engine (Original shipping container), includes clutch assembly, bell housing, a/c compressor, wiring harness: $13,000.
Used 90 engine (less throttle body and coil tray), includes DIS ignition module, a/c compressor, wiring harness & flywheel clutch assembly: $5,800.
billkirchhofer is offline   Reply With Quote
Old 05-10-2023   #2
2poor4aZR1
Default Re: LT5 Engine & Components for Sale
Tensioner by chance?
2poor4aZR1 is offline   Reply With Quote
Old 05-12-2023   #3
NJVll
Interested, Pics please
NJVll is offline   Reply With Quote
Old 05-29-2023   #4
NJVll
Interested
Old 06-12-2023   #5
drcuadrado@gmail.com
Hello do you have the ecm?
drcuadrado@gmail.com is offline   Reply With Quote
Old 08-14-2023   #6
gromano973@gmail.com
Do you happen to have the tensioner pulley by any
gromano973@gmail.com is offline   Reply With Quote
