Old 04-16-2023   #1
thestrawhead
Default Still running rough[emoji35][emoji30][emoji19]
After replacing the cam positioning sensor that I got from Jagpanzer on the registry(thank you!) my 90 Zr-1 ran great and check engine light went off and code cleared. Then, shortly after it started running rough again. Tapped on the E.C.M and it ran smooth...for a short time. Had to limp it home, and it would not go into full power mode, regardless of where I turned the valet key. Can't find an E.C.M. for it. A guy said he would rebuild it for $600. Ugh. Not sure Bout then. Getting nickel and dimed to death lately with only 24k miles on it[emoji19]
Sent from my SM-G960U using ZR-1 Net Registry mobile app
thestrawhead is offline   Reply With Quote
Old 04-17-2023   #2
G8nightman
G8nightman's Avatar
Default Re: Still running rough[emoji35][emoji30][emoji19]
Try opening up the ecms cover and reseating the chip.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 04-17-2023   #3
Do this ^. Check for codes with a code reader or short the ALDL pins. Turn ignition to ON position but Don?t Start. Does CEL light flash once? If it does, ECM checks out.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-18-2023   #4
thestrawhead
Thanks!
Old 04-18-2023   #5
Young1
Young1's Avatar
First remove each of the colored connectors. Spray all with electrical contact cleaner. Reinsert. Next remove the small PROM cover. Remove the blue prom. Spray. Reinsert. Chances are good it is just a connection. Tug a bit on each of the wires to make sure they are connected well. Another option is to send it to Marc Haibeck for repair. Tapping it sure seems like a poor connection or just a failed solder joint inside. 35 year old parts need a little love. Be patient. Buying a 35 year old replacement can buy you just another set of problems.
Steve Young
Second Owner
SOLD
SOLD
