03-23-2023 | #1 |
Royal Purple oil filters
Has anyone tried Royal Purple oil filters on their car? I use their oil since my mechanic sells it and he asked me if I knew of anyone who had tried the RP filters on a LT5.
Access to Bosch 3401 or AC Delco PF970C (blue) here in Norway is very limited at best. All input on other good filters are appreciated too. Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust |
03-24-2023 | #2 |
Re: Royal Purple oil filters
I've been using Wix on mine. Mobil 1 is another choice as well
93 ZR-1 Red/Red 415ci Jeal cams/headers, hf cats, B&B Wilwood brakes, DRM coilovers 94 ZR-1 Red/Blk 368ci SW headers, hf cats, Corsa 16 GT-R Blk/Blk Stg1 3.8 BL1200X, Shep1k, Motec 1250 whp on pump e85 |
03-25-2023 | #3 |
How would one distinguish good vs. bad oil filter trough use? I think the only way is to disassemble and compare the quality of internal construction.
03-25-2023 | #4 | |
03-25-2023 | #5 |
Marc Haibeck has some good information on his website about oil filters: http://www.zr1specialist.com/HAT%20W...ers%202006.htm. --Bob
03-25-2023 | #6 |
Thank you for reminding me of anti-drain back being critical. Perhaps checking the weight before install and after engine shut down after so many hours would provide a meaningful info.
I seriously considered pre-luber a few years back. But then, blown head gasket, rebuilding the motor twice, sent me in a different direction. Now a days, I log less than 5,000 miles per year and the Z will probably out live my left leg. |
03-25-2023 | #7 |
I use Mobile M1-207s.......
I prefer an oil filter that will not create a mess when removing it over night since the LT5 Oil Filter sits on top with opened end down. A Mobile M1-207 works perfect in that case. Post 3 - LT5/ZR-1 Fluids |
03-26-2023 | #8 | |
03-26-2023 | #9 |
Go ahead and try the Royal Purple if your mechanic and dealer can get it for you. Support the locals. The engine will tell you on start up if it likes it or not. Fram, Bosch, Delco were no go clattering for me. Sticking with WIX 51324.
03-26-2023 | #10 | |
