Old 12-18-2022   #1
98indypacer
Default Looking for BMCB Bin File
I have a 94 ZR-1 that has the BKKR calibration and looking to upgrade it to BMCB. Does anyone have a source to download the BMCB bin file?
98indypacer is offline   Reply With Quote
Old 12-18-2022   #2
Default Re: Looking for BMCB Bin File
I think the BKKR was the latest upgrade for 93-95 LT5s.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 12-18-2022   #3
98indypacer
That?s what I thought until I read this in a presentation from Marc Haibeck.
?For ?93 to ?94?s GM issued BMCB with Product Service Bulletin 576514 dated 18
September, 1995. It addresses a problem with a sag or surge on light throttle acceleration below 2500 RPM. It also corrects an intermittent ASR error that a few cars had.?
I read that BKKR was released 11/12/93 and was replaced by BMCB.
Old 12-19-2022   #4
Looking at my library, the BKKR bin is an $F0 Mask ID. The latter $F0A bin file you are looking for is the BFDM. At least that's the broadcast code I have. Not sure if there was an earlier or later update beyond that.
Old 12-19-2022   #5
I found a copy of the BMCB bin file. Its identical to the BKKR bin as both are $F0 bins. The BFDM bin is an $F0A and appears to be the latest update.
So to load it, u will need the $F0A .xdf for TunerPro
Old 12-19-2022   #6
98indypacer
Thank you! I found this chart here in the Registry that helps. Do you have a copy of the BMCB file that you could send me? I can pm my email address.
Old 03-20-2024   #7
scorp508
Does anyone have $F0A XDF? I have $F0 but have not seen an $F0A to download and searches are coming up short.
*edit*
Actually, if BMCB (F0) superseded BFDM (F0A) a couple years later going by the chip P/N and release date, then I may not even care if I have the F0A XDF.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
Old 03-20-2024   #8
scorp508
For what it is worth, there was a $F0A .XDF here.
http://www.gearhead-efi.com/Fuel-Inj...ull=1#post2697
When compared to F0 there's little different in the F0A XDF other than unique IDs and address changes in a couple volumetric efficiency tables. Would be interesting to compare the BINs for them.
Old 03-20-2024   #9
I think u could essentially disregard the BMCB and just load the BKKR. The diff between the FOA and FO is pretty insignificant at this point.
Old 03-20-2024   #10
scorp508
Curiosity often gets the best of me.
