Old 10-31-2022   #1
wagonwx
Default Alternator R/R-Gaskets
Looks like I have the flickering lights, bouncing amp meter gauge syndrome. I did a test on the alternator and it appears to be bad. I just R/R'ed the plenum for a tuneup and replacement of some bad injectors. The plenum has been on only one week. Would I need to get new plenum gaskets, again? or can I carefully lift the plenum, do the alternator swap and reuse the gaskets? Any recommendations on Alternators or should I try to rebuild it and the voltage regulator?
Thanks.
wagonwx is offline   Reply With Quote
