Old 09-21-2022   #1
YoungGun
Question Exhaust Removal
Removing the exhaust later tonight. Never been under the car before. Any documents/threads out there that show you where all of the attachment points are to save some time?
-YoungGun
YoungGun is offline   Reply With Quote
Old 09-21-2022   #2
Figure8it
Figure8it's Avatar
Default Re: Exhaust Removal
I removed mine this past winter. It's pretty straight forward with the hangers and muffler mount points. I removed all the hardware starting at the headers and worked back towards the mufflers. Once it was all removed, I had a small weld to break and was able to slide it off/back using a floor jack. Good luck on your project!
I have a few pics in a post I put up afterwards here:http://www.zr1.net/forum/showthread.php?t=33708
You should be able to see the mounting points in the pictures to give you an idea of where things are located.
Figure8it is offline   Reply With Quote
Old 09-21-2022   #3
CamP
If you place a floor jack in the right place, the whole catback will balance nicely. The center of gravity is near the rear spring loaded mounts on a Corsa.
CamP is offline   Reply With Quote
Old 09-22-2022   #4
Yep, that's the way I used to take mine off and reinstall them. I positioned the floor jack after I had removed most of the attachments, removed the last ones, lowered the exhaust on the jack and rolled it out the back. Really pretty easy to do. --Bob
