Old 08-21-2022   #1
Ozruss90
Ozruss90's Avatar
Default A/C blower fan won?t turn off
Drove home from a car show last weekend and when I got home and turned the engine off, I noticed the A/C - Heater fan was still running. Tuned the key back on and tried the controls on the dash, but made no difference. Turned ignition key off and removed key. Fan still running. Had to disconnect the battery.
Any advise on where to start looking. 1990. #2774
Cheers,
Russell 🇦🇺
Ozruss90 is offline   Reply With Quote
Old 08-21-2022   #2
CamP
Default Re: A/C blower fan won?t turn off
May be a bad blower control module. It's on top of the blower box on the passenger side. May also be the blower motor relay.
CamP is offline   Reply With Quote
Old 08-21-2022   #3
Ozruss90
Ozruss90's Avatar
Thanks CamP.
Got to start somewhere. Until l get it sorted, l will have to disconnect the battery each time l stop. PITA.
Cheers,
Russell 🇦🇺
Old 08-21-2022   #4
CamP
Originally Posted by Ozruss90 View Post
Thanks CamP.
Cheers,
Russell 🇦🇺
You can pull the power supply connector on top of the blower case. That's a lot easier than disconnecting the battery.
Old 08-21-2022   #5
Mystic ZR-1
Mystic ZR-1's Avatar
or pull the fuse
Old 08-22-2022   #6
Ozruss90
Ozruss90's Avatar
or pull the fuse
Derrr, l didn?t think about that. Simple solution until l get time to start searching for the problem. Thanks for that 👍
Old 08-22-2022   #7
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Spot on!
Marty
Old 08-22-2022   #8
CamP
The ac fuse may not stop the blower. The blower is wired directly to the battery through a fusible link. The power feed to the blower control module is always hot.
Old 04-28-2024   #9
Starman
Starman's Avatar
Same thing just happened to me yesterday when going to a car show-man those things are hard on the cars! What was the fix here? Just getting ready to dig in today.
Starman is offline   Reply With Quote
Old 05-01-2024   #10
scorp508
My 87 w/C68 did this. The blower motor control module fails in the "on" position and runs until the battery drains.
It looks like this; https://www.ebay.com/itm/19630392277...mis&media=COPY
The non-C68 cars have a Blower Motor Resistor which looks very different.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite
1994: ZR-1 #150, Admiral Blue / Black
2015: Z06 Coupe, Z07, M7, Arctic White / Red
