Old 07-25-2022   #1
Corvette95
Corvette95's Avatar
Default Pre lube - Pre oil after sitting
Well, due to life events, my ZR-1 hasn't been cranked/started in over 6 months. I know this is boarder line on the need for pre-oil. I searched the threads, I KNOW there is at least ONE article on this, maybe from Heibeck. Could any one help me find it or give me a good procedure. I know, it's not technically needed, but I want to anyway. Thanks! (Mobile 1 with Bosch filter)
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 07-25-2022   #2
secondchance
Default Re: Pre lube - Pre oil after sitting
Towards the end of the article.
http://www.zr1specialist.com/HAT%20W...ping%20LT5.pdf
Old 07-26-2022   #3
CamP
Those are great tips for a ultra low mileage car coming out of hibernation.
Sounds like overthinking it a bit for a driver thats been off the road for a year, or so. All my cars have gone thru periods of years between starts without doing anything but charge the battery and fire it up.
CamP is offline   Reply With Quote
Old 07-26-2022   #4
Many years ago, I acquired a lot of about 30 LT5 engines that came out of GM storage left over from all sorts of projects, Active Suspension, Phase 2, 89 models, warranty replacements, engineering testing, "window" for cam chain testing, etc.
The engines were placed in open crates, some assembled, some partially disassembled, no protection or preservation was ever intended. These engines had bee sitting for 10+ years. I disassembled a few and without exception, there was oil still present on all the rod bearings as if the engine was recently run.
One of the complete engines was installed, started & used for several months without issue, except for a leak in the front cover or seal area.
I have handled 7 crate engines & sold all to customers who followed my recommended protocol to bring them to life. Without exception, all of them started & ran just fine. Engine oil had to be drained before shipping, but to my knowledge, none of them were pre-oiled before starting. These are engines last run on a dyno in 1993, so at least 15 years.
Part of my protocol was to remove the plugs, squirt a small amount of light motor oil in each cylinder, crank it over a few revolutions to lube the cylinders & pump oil to pressurize the oil galleys before re-installing the plugs & running.
Nothing wrong with pre-oiling a newly built engine especially, but I don't really think it is at all necessary on an engine last run a few months or even years ago. You could always just pull the plugs, & crank the engine over until you begin to see pressure.
Just my 2 cents worth......
Old 07-26-2022   #5
These engines had been sitting for 10+ years. I disassembled a few and without exception, there was oil still present on all the rod bearings as if the engine was recently run.
I don't really think it is at all necessary "Pre-Oiling before starting" on an engine last run a few months or even years ago. You could always just pull the plugs, & crank the engine over until you begin to see pressure.
"Added information in Green"
Excellent Information Jerry (A26B) and from one who has the most experience with the necessity of pre-oiling engines issues
Old 07-26-2022   #6
Corvette95
Corvette95's Avatar
Thanks! That was what I was looking for! Also, I appreciate the response Jerry. I know that you are right and that pre-oiling is not needed, but to my OCD mind it is. I normally don't let any of my Corvette's go for more than 3 months without starting and getting fully up to temperature.
Old 07-28-2022   #7
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Agree with Jerry.
Nice to do.
Necessary?
No.
I once parked my Z for what I thought would be a month or two.
Turned into 3 years.
Bumped the key, started immediately, like I had just shut it off.
Oil pressure came up near instantly.
Did not even have chain rattle.
Sometimes we just worry just a bit too much.
Enjoy your Z
Marty
Old 07-28-2022   #8
CamP
Paralysis by analysis
Old 07-29-2022   #9
Way too much trouble that's not needed. My car will sit for months at a time. Put gas pedal to floor and crank engine a few seconds. Take foot off gas pedal and start. This procedure is used to clear a flooded engine,engine will crank over but won't start with the pedal full depressed.
