My 1990 ZR-1 with C68 AC is not blowing air out of the dash air vents. It is blowing cold air out of the floor and defrost vents. Anyone else have this issue?
The problem is your HVAC controller located above the gas pedal and it is a bear to get to. You will need to source a replacement. At least it's not a ZR-1 only part. I remember somebody on the board here who was able to rebuild his but that was a long while ago.
![]() Join Date: Sep 2008
That is the default mode when failed, so that you can see in the cold or wet when defrost or defog is required.
Go to BATEE.com Bryan's site can help you determine and confirm which part has failed. As the poster above said, likely the controller, but there are multiple components that could cause this. Not complex if the programmer or controller. Check out his site. He is THE BEST! www.batee.com ![]() Marty |
#4 | |
![]() Join Date: Aug 2006
Below Is QB93Z thread on replacing the programmer.
http://www.zr1.net/forum/showthread.php?t=27542 Jim as far as I know went in the deepest with HVAC diagnose and repair. Reach out to Jim (QB93Z) and tap his knowledge. Good luck! |
#6 | |
I hope it's that easy! I replaced the ac programmer back in '97 and that job was no fun! |
![]() Join Date: Sep 2021
I?m having the issue where I have cold ac but it only blows out of the foot and defroster vents. I?m guessing it is possible the HVAC programmer then?
I never followed up on my vent issue. It turned out to be the vacuum line to the ac controller was pinched between the plenum and injector housing.
#9 |
![]() Join Date: Sep 2016
That is correct. Cruise and AC share a common vacuum source on RH plenum. Secondaries vacuum source is the pump and LH plenum. Stuff under the hot plenum shrinks and ages and gets loose. Not as likely under the dash. I would also consult the FSM and follow the diagnostic tree. Vacuum stuff is pretty easy. Electrical not so much. Your patience and diligence keeps the legend alive.
