Old 06-20-2022   #1
Tkrahn77
Default Overheating issues.
Hi my name is Trevor,
I am new to this whole forums thing but I have a question. I am by no means a mechanic but I understand quite a bit on vehicles. I'm more of a parts swapper. Well I have a 1990 ZR1 and have been going through quite a bit of issues since buying her. I have figured out most of the issues. I am now having over heating issues. I swapped the thermostat bled the air out still over heating. I removed the thermostat housing and cleaned up everything. I am looking for this sensor and wanted to swap it out but can't find it anywhere. If someone could direct me in the right path would be greatly appreciated. I am working my way up to the water pump and am hoping to solve the issue before getting to that point.
Tkrahn77 is offline   Reply With Quote
Old 06-20-2022   #2
1991 Corvette ZR-1
Default Re: Overheating issues.
Have you had a chance to check the air gap between the radiator underneath the shroud? How quickly does it overheat? In changing the thermostat, how did you refill the coolant? When refilling the coolant and it appears full in the surge tank it is possible to still have a decent amount of air still in the system. A trick that one of our forum veterans taught me was when the engine is cold and you start it, put your hand on the coolant tube outlets on the injector housings and the cam covers. If the cam covers are getting hot, but the coolant tubes are staying cold, air pocket issues. If the tubes get hot and the cam covers stay comfortable to the touch during that time, you are good to go.
Also, surge tank should have a visible return stream while the engine is running. While the engine is cold, take the surge tank cap off and start the car and observe if that is present. You can also check your fan operation by using a paper clip to jumper the diagnostic terminal when the Key in the on position but not cranking it. That is a start anyway, hope some of that is helpful info.
1991 Corvette ZR-1 is offline   Reply With Quote
Old 06-20-2022   #3
Tkrahn77
I used the over flow funnel ran the engine for about an hour watching the flow of the coolant it did burp quite a bit. The temperature didn't get to high until I took it on a drive. Then it took about five minutes into the drive then over heated again.
Old 06-20-2022   #4
dredgeguy
dredgeguy's Avatar
Not sure how many miles you have on the car but our C4's are bottom feeders, everything gets sucked up into the radiator. I had so much very fine grit in mine it blocked out the air. During one of our Wazoo maintenance days we took out the stock radiator and after an hour of shaking and tapping on it, fine grit material kept coming out. We knew there was no saving it. A new DeWitts solved that problem.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 06-20-2022   #5
Tkrahn77
I have 71500 miles. I just ran water into the radiator from to hose the water flowed out clean steady flow. I did have a little debris inside the thermostat hosing assembly. I cleaned it out last night. I have yet to reinstall it and check to see if that could cause it to over heat.
Old 06-20-2022   #6
Hobbes
I'm in Houston also and was experiencing some uncomfortably high temps while driving a couple weeks ago. I ended up removing and deep cleaning the radiator (30 years of dust/dirt/fur...etc), brushing/blowing out dirt from the other coils in the stack, installed a 170 degree thermostat and updated chip with lower fan turn-on temps from Marc Haibeck. I took it on a brief test drive this afternoon and it appears to be making a positive impact.
I'll try to go for a longer drive later today or tomorrow and report back. My bet is that 90% of the improvement came with the deep cleaning of the radiator.
1991 ZR-1 Dark Red Metallic/Black #1648 Stainless Works headers, OBX cat-back, Haibeck chip, Haibeck 170 degree thermostat, throttle body coolant bypass, led headlights & fog lights, Etoile 455 3-piece wheels.
1973 Stingray Black/Black #421. ZZ4 with Holley Sniper EFI, Tremec TKO-600 5 speed, 3-row aluminum radiator, 18? Foose legend wheels, + lots more.
Hobbes is offline   Reply With Quote
Old 06-20-2022   #7
Hobbes
Ran around town for about 45 minutes. Outside temp about 102. Mostly driving through neighborhoods with a few ?spirited? runs. AC blowing full speed the entire time. Monitored the engine/coolant temp through the hvac readout and never crossed above 98c or 208f.
Hope this helps give a gauge for you on next steps.
Old 06-20-2022   #8
Young1
Young1's Avatar
Pull out the radiator. You will find it clogged with sand and debris. I rake the fins with a fine wire brush we use on the Yorkies. I put screen on my air inlet too. Make sure both fans are running too. I was surprised how bad it was on at 40k miles.
Steve Young
Second Owner
SOLD
SOLD
Old 06-21-2022   #9
Matt B
Matt B's Avatar
I agree with Steve. Last year I had to replace the radiator of my 2008 Audi A6 and was SHOCKED about the amount of fine sand and dusty debris that came out of that thing.
The accumulation of road dirt is crazy and for sure heavily affects cooling performance.
You can't eliminate that by flushing the system as this happens externally.
ZR-1 #638/1991
Matt B is offline   Reply With Quote
Old 06-21-2022   #10
Corvette95
Corvette95's Avatar
If you remove the radiator and entire front airbox (not air filter cover- the upper and lower shroud), while not exactly a pleasant job (read tech info stickies for help) , you will find access to the thermostat and hose much easier- congrats BTW on getting it out like you did). You will also have access to the oil filter housing and can fix any likely oil leaks you have there (they pretty much all do). Your fan(s) can also run and be bad at the same time. They just don't turn fast enough to do any good. Compare each fan to each other and make sure they run as needed with a/c pressure switch.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
