Old 05-26-2022   #1
Perry Mitchell
Default which gas
In my area, I have three choices of gasoline, Ethanol based 91 octane, non- ethanol 87 octane, and 100LL Avgas. Which would be the best fuel to use in my stock '91 LT5 that doesn't get driven a lot? Which fuel lasts the longest in the tank?
Perry Mitchell is offline   Reply With Quote
Old 05-26-2022   #2
spork2367
Default Re: which gas
Ethanol based 91? Or 91 octane with ethanol? "88 Octane" is E15. So I'm guessing you mean regular 91, but with ethanol. Typically 10% or less. That is the best choice, with replaced injectors. Original injectors are not ethanol compliant. Non-ethanol 87 is on the low end for the high compression ratio. 100LL is not only not legal to run, but extremely costly and will damage your catalytic converters over time.
Old 05-26-2022   #3
Perry Mitchell
Yes, I mean regular 91 octane with ethanol. My injectors have been replaced with Jerry's FIC units. I don't have cats on the car as this motor is in a 67 Camaro. The problem with ethanol gas is it doesn't stay good for long. I've been running non-E gas in my other collector cars and equipment without issues.
Old 05-26-2022   #4
spork2367
Obviously, the LT5 was designed around non-ethanol fuel. 87 octane is just a bit on the low side. Even without cats, I don't think I'd run 100LL (if for no other reason than the price). You also have to remember that it has slower flame propagation than mogas which will tend to increase operating temperature a bit. It will also kill your O2 sensors eventually.
Old 05-26-2022   #5
CamP
Since you replaced the injectors, I'd say run the 10E 91 octane pump gas.
100LL is one of the best storage fuels, but the lead will kill the cats and eventually foul the o2 sensors.
I blend 87 non-ethanol and 100LL for my C3 big block.
CamP is offline   Reply With Quote
