05-13-2022 | #1 |
Console removal
I am in the process of removing the console from my 91ZR1 & am stuck. Does anyone have a video detailing the removal? All of the visible screws are removed & it won't budge. Any advice would be appreciated. TIA.
lorne 1748
lorne # 1748 Stock except for a modified Corsa exhaust. When the flag drops the bull sh1t stops! |
05-13-2022 | #2 |
Re: Console removal
For your center console there is only three screws. Two of them are located in the rear of the console (7mm), right and left side, when you lift the console arm rest and the other is located under the front cup holder. The console should lift and then you will have to disconnect the wires for the button for the rear hatch, the cigarette lighter and the "power key" module. This is pretty straight forward.
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker |
05-13-2022 | #3 |
Re: Console removal
Are you talking about the front stereo section or entire console under the armrest storage and all?
Here is a video for the front stereo shifter area. https://youtu.be/wQj_MB2-6Y0 Sent from my iPhone using ZR-1 Net Registry
05-14-2022 | #4 |
Re: Console removal
Thanks for info.
lorne #1748
