Old 03-21-2022   #1
Ozruss90
Ozruss90's Avatar
Default Rear amber indicators.
Can anyone steer me in the right direction on how to make the inner 2 lamps only, work as the indicators. I have the amber lenses. It?s an state requirement here in Australia for registration that the rear indicator be amber. Thanks in advance.
Ozruss90 is offline   Reply With Quote
Old 03-21-2022   #2
dredgeguy
dredgeguy's Avatar
Default Re: Rear amber indicators.
Not sure if they have a kit for what you are looking for but worth a try:
https://www.webelectricproducts.com/
Good luck and let us know.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 03-21-2022   #3
G8nightman
G8nightman's Avatar
You should be able to modify the harness. You can use a test light to figure out what wire does what and then just cut the ones you don't need to get the configuration you want
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 03-21-2022   #4
you will need to run an extra wire.. from the turn signal switch under the dash, or snag the brake light wire from the CHMSL.. I ran an new wire form the switch for my euro lamps, that new wire became the brake light and the existing wire became the turn signal.
Old 03-22-2022   #5
davids1978
You will need to modify your tail lights, parkers and install side markers to get a VASS (as well as set belts etc). I have some PDF instructions but can't seem to post them here, send me a PM and I'll try to attach it to the reply.
The alternative is to have someone take care of all modifications, engineering & RWC - I can recommend someone in Melbourne if you want to go down this path (he did my 95 last year).
davids1978 is offline   Reply With Quote
Old 03-22-2022   #6
Ozruss90
Ozruss90's Avatar
Thanks David, PM sent.
