Old 03-05-2022   #1
Bruce Hazell
Default U joint replacement
Hi all,
I just replaced my clutch and while that being done mechanic suggested I replace my rear u joint which is a little loose.
Have been on line looking for a replacement u joint and am a little confused with all the make options that vary in price and those that are with grease fitting or not as I believe originals were. 1991 Zr-1 50.000mi.
Is there just an OEM u joint kit still available or can anyone suggest the next best option??
Bruce Hazell is offline   Reply With Quote
Old 03-05-2022   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: U joint replacement
Denny's Driveshafts has what you need.
https://www.dennysdriveshaft.com/p42...0x_4_3_70.html
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-06-2022   #3
Post 240 - New Rear Wheel Bearings and Half Shaft U-Joints........
https://www.corvetteforum.com/forums...post1591920876
Post 241 - Rebuilt Black Label Transmission Installed and New Driveshaft U-Joints.......
https://www.corvetteforum.com/forums...post1592505462
Old 03-07-2022   #4
Bruce Hazell
Thank you for the info!!!
