Old 01-23-2022   #1
AndrewL
Default Leaking cylinder head plug
Hey guys
I'm going through my new to me 91 ZR-1 and going over it to make sure everything is okay and cleaning it up to my standard.
I've noticed oil slowly leaking from the plugs pictured at the back of the cylinder heads.
The service manual doesn't seem to go into enough detail to confirm that the pictured plug is the lifter gallery plug, and if so what the torque value to reinstall it is.
Am I right in thinking the pictured plug is the lifter gallery plug?
Anything I need to be mindful of if I'm looking at removing them so I can reinstall them and reseal them with Loctite 565?
AndrewL is offline   Reply With Quote
Old 01-23-2022   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Leaking cylinder head plug
These are tapered pipe plugs and can be difficult to remove. Suggest resealing only the ones that are leaking.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-23-2022   #3
Jagdpanzer
Jagdpanzer's Avatar
They are for plugging the ends of the drilled oil galleries that feeds oil to the lifters and and cam bearings.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-23-2022   #4
Have same issue. Same drip has been there for years. I don?t see spots on the vround or smell burning oil,
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 01-24-2022   #5
AndrewL
Thanks guys, much appreciated. Based on the feedback received and the fact I'm likely to pull the engine within the next year I'll monitor it and if not leaking too badly I'll leave it until the motor comes out.
