Old 09-19-2021   #1
tf95ZR1
tf95ZR1's Avatar
Default Garage Door Opener
I'm tired of searching for my "clicker" to open my gate/garage door.
I remember in the past someone offering a HomeLink type visor.
I'm looking for either this built-in or SMALL clip on module.
What do you guys have/use?
TIA!
Ted
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 09-20-2021   #2
Young1
Young1's Avatar
Default Re: Garage Door Opener
Mine is Velcroed to the carpet in the console. Adhere the loop side to remote and voila
Steve Young
Second Owner
SOLD
SOLD
Old 09-20-2021   #3
I have the home link visor I bought it from ecklers a long time ago. However for many years I just velcroed it above the mirror. As I use nothing but chamberlain belt driven garage door openers for my three doors the rectangle opener fits up there nicely.
Why do I use belt driven door openers? I remember my buddies 67 Shelby Mustang underneath a sprocket and chain unit that broke and flopped and trashed the top of his roof until the chain and sprocket fell onto the roof of his car. Needless to say the top of his car required a total respray.
Belt is the only way to go if you want quiet and because of this lesson learned the hard way. When I moved in all three units were immediately replaced. GC
GC
Old 09-20-2021   #4
Great White
Great White's Avatar
I keep my remote in the console as well, clipped to one of the cassette dividers.
Anybody seen the new screw-drive openers? They're pretty nice.
Sent from my BBF100-2 using ZR-1 Net Registry mobile app
Great White is offline   Reply With Quote
Old 09-20-2021   #5
Mikey
Mine is simply held on with standard visor clip.
As for garage door openers, the lift master shaft opener is the only way to go when you have single doors for each bay. Nothing overhead. Really cleans up the ceiling and makes enough room to stack two cars with a lift.
Mikey is offline   Reply With Quote
Old 09-20-2021   #6
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
1- Buy a used sun visor from a C-5 with Homelink.
2- cut the visor fabric and remove the Homelink transmitter and wire assembly
3- CAREFULLY make a cut in your sun visor, and using the old C-5 visor as a guide, make the appropriate holes and cuts on your C-4 visor.
4- feed the wire through and connect it to the visor vanity mirror light wires
5- put it all back together.
You now have Homelink in your ZR-1.
Marty
p.s.
Went with the liftmaster and high lift door rails in 2005.
added a second when the 2nd lift was added.
Those liftmasters are indeed the best!
Old 09-20-2021   #7
Liftmaster and Chamberlain are pretty much the same.. for the tall stalls with Lifts the Jack Shaft openers are a good option.
As for Belt drive, that is all I have as well.. this week I have a Liftmaster\Belt Drive\WiFi\Battery Backup With Camera
Old 09-20-2021   #8
Yep they are almost identical only option I don't have is the camera to that list lol. They even offer "wraps" for the units lol. All it need is a rotisserie option next. lol
Old 09-20-2021   #9
Ted here is mine opener velcroed on the roof header above the mirror and you can see the home link visor buttons in the reflection as well. You don't need to pull the remote it works fine from there. GC
File Type: jpg 61B858AD-51F1-484A-83E3-087F70258C3C.jpg (95.2 KB, 7 views)
