09-18-2021 | #1 |
FX3 SRC Frustrations - I've Done My Homework!
1991 ZR-1.
SRC light came on after I had the fuel pump replaced. Likely unrelated, but just in case. Checked the error codes, and it threw a 33. From what I understand, that's the Left Rear actuator. Bought a new $200 actuator from Corvette Central. Replaced it and when I shook the old one, it rattled. New one did not. So assumed something was broken in the old actuator. Put it all together, tried the C/A 2 seconds 3 times thing and the damn error 33 still comes up. Disconnected battery for 15 minutes. No luck. Now I wish I had tested the new actuator by watching to see if it spun before I installed it, but I did not. What am I missing? For now I'm so frustrated I just unplugged the SRC module in the trunk to turn the light off. HELP!
1991 Corvette ZR-1 - Polo Green/Saddle 2010 Mustang GT Convertible 2003 Thunderbird 1973 International Scout 1967 Pontiac GTO 1965 Mustang Convertible 1958 Plymouth Belvedere Convertible 1957 Ford Thunderbird Last edited by carguyjoe; 09-18-2021 at 12:53 PM. Reason: spelling |
09-18-2021 | #2 |
Sorry I just woke up in case this is a dumb question. Did you clear the code 33? If not, it will keep showing up and will not clear itself.
Could you also have someone turn on the ignition for you while you are at the actuator to feel or hear it reset? Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 Last edited by HAWAIIZR-1; 09-18-2021 at 02:31 PM. |
09-18-2021 | #3 |
Re: FX3 SRC Frustrations - I've Done My Homework!
I tried many times to clear it by jumping the A and C for two seconds at a time, three times. Won't clear.
I can hear it moving when I turn on the ignition.
1991 Corvette ZR-1 - Polo Green/Saddle 2010 Mustang GT Convertible 2003 Thunderbird 1973 International Scout 1967 Pontiac GTO 1965 Mustang Convertible 1958 Plymouth Belvedere Convertible 1957 Ford Thunderbird Last edited by carguyjoe; 09-18-2021 at 07:55 PM. |
09-18-2021 | #4 | |
Hmmm?sorry I can be of more help; it has been awhile. That?s a good sign you can hear it. Did you try to drive it yet? https://www.corvetteactioncenter.com...src_page2.html https://www.corvetteforum.com/forums...ng-or-not.html Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 Last edited by HAWAIIZR-1; 09-18-2021 at 08:37 PM. |
09-20-2021 | #5 |
Did you adjust the top nut of the shock no more than 1.5 threads down before putting the actuator on? I suspect it's timing out because the actuator ride height is wrong.
09-21-2021 | #6 |
This probably is your issue. I struggled with an actuator code for about a year, the shop messed with it a couples times and it always came back. What it turned out to be the top nut was too loose. There is a spec in the manual I think it says a minimum of 5mm clearance, Mine was at 3.5 on one side. After making that adjustment I never got the code again.
09-22-2021 | #7 |
Thanks guys. Will check that.
1991 Corvette ZR-1 - Polo Green/Saddle 2010 Mustang GT Convertible 2003 Thunderbird 1973 International Scout 1967 Pontiac GTO 1965 Mustang Convertible 1958 Plymouth Belvedere Convertible 1957 Ford Thunderbird |
09-22-2021 | #8 |
OK just to close this out.... I took the shock back off and the gear turned in both directions with no stops. So the actuator was not able orient itself I guess.
Put on a used shock I got off eBay and all is well. Didn't even have to clear the code 34. I probably wasted $200 on a new actuator I didn't need, but I'll justify it by listening to the rattle in the old one. If if nothing else, I guess I have an extra. Thanks again to all for the tips!
