![]() Join Date: Mar 2018
I need a new leaf spring since the one on the car has started to crack.
What type and from where do you recommend me buying? Any other upgrades I should do at the same time? Thanks guys. Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust |
![]() Join Date: Aug 2006
What year?
![]() Join Date: Nov 2011
I'd check with Mirrock for a used one.
GM tested these springs for millions of cycles. I think they wore the machine out twice, the spring was fine.
#7 | |
![]() Join Date: Sep 2008
Hyperco probably made the originals, have had one on the back for many years. I believe they are available through Vette Brakes. You will have to paint it black.
#9 |
I found a pair of originals, both front and rear, so it worked out in the end.
#10 | |
![]() Join Date: Jul 2016
