Old 08-27-2021   #1
jad1014
Default 3rd brake light not working. CHMSL
Hello,
My CHMSL are not working. My rear brake tail lights work and hazards work. I unplugged the two connectors going into the stop light switch and the smaller light blue one has no power in the connector. I assume it should have power? Where should I look next? I am afraid i am beyond my threshold with solving electrical issues.
Thanks
Jason
jad1014 is offline   Reply With Quote
Old 08-27-2021   #2
Matt B
Matt B's Avatar
Default Re: 3rd brake light not working. CHMSL
Brake lights are all in one connector. The other one is to disable the cruise control.
Energy is provided via the center wire whereas the two outer ones route the current to the brake light "clusters" - 4 lower and central high.
Remove the switch (just pull it out towards the inside of the car) and measure the resistances between center and both outer contacts.
If there is an issue open it by carefully prying out the 6 small latches and thoroughly clean the contact points.
Sent from my SM-G991B using ZR-1 Net Registry mobile app
ZR-1 #638/1991
Matt B is offline   Reply With Quote
Old 08-27-2021   #3
Corvette95
Corvette95's Avatar
I MAY be wrong, but going from memory, both switches will cause an in/op third brake light. I vote either bad switch or just as likely, all those expensive little bulbs in the lamp are out.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 08-27-2021   #4
Young1
Young1's Avatar
Go to Napa and get a new switch. Been there done that. I even took the 30 year old apart and cleaned it. It still did not work. Put in a new one and good for another 30 years!
Steve Young
Second Owner
SOLD
SOLD
Old 08-27-2021   #5
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
post 3 and 4 are correct.
It is almost a 50-50 chance that it is one or the other.
Every time we check the switch first, it's all of the bulbs out.
If we check the bulbs first, it is the switch.
Trim limber techs probe the switch first.
The more "executive cut" techs opt to probe the bulb sockets first.
Working under the D/S hush panel can be a contortionists' practice session.
Marty
Old 08-27-2021   #6
jad1014
Marty
Thanks to all. It is only one switch to replace, correct? I though the second switch with the unused plug was for cruise control.
Should this connector have power:
Old 08-28-2021   #7
jad1014
Hi - i replaced the switch and it didn?t solve the problem. Whats a good way to test for power at the bulb? I put a tester on the sauder back section of the board that holds the four lights, but not sure if that?s a good way. What?s a good source for replacement bulbs?
Old 08-28-2021   #8
HAWAIIZR-1's Avatar
Some of us have upgraded to LED strips.
http://www.zr1.net/forum/showthread.php?t=30223
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 08-29-2021   #9
Matt B
Matt B's Avatar
Maybe to open the brake light and measure at the sockets. If you have to replace bulbs you need to open it anyway.
You may also try to measure resistance between the plug and ground. If the circuit is closed (I.e. At least one bulb is okay, circuit board is okay and there is a proper ground) there should be any reading. If there is no reading circuit is broken somewhere. From here I'd open the brake light and check everything inside.
As for the bulbs due to the lack of availability of that US standard on my continent I replaced mine with 8 watts G4 standard socket halogen bulbs. They are a bit larger but squeeze in nicely. These are also available as LED.
ZR-1 #638/1991
Old 09-09-2021   #10
jad1014
I don?t think I have power to the CHMSL bulbs. The SLS switch has been replaced and I found some 891 bulbs and replaced two with no luck. I think that?s about as much as my skill set will offer for this problem. I didn?t bother with the 20A fuse since my hazards work. Any other thoughts? Thanks again.
Jason.
