Old 08-21-2021   #1
Beaver's 90ZR1
Default Injector Housing Bolts
Can someone please help me. I have a 1990 ZR1 Corvette. I need to know the sequence for tightening the injector housing bolts. I have every manual for the car and can find every bolt tightening sequence for the engine, but CANNOT find the sequence for the injector housing. Thank you.
Beaver's 90ZR1 is offline   Reply With Quote
Old 08-21-2021   #2
Locobob
Default Re: Injector Housing Bolts
I don't see a torque sequence specified for the injector housings in my FSM, just says tighten to 20 ft lbs. I think just starting in the middle and working to the edges is the prudent method.
Robert
Old 08-21-2021   #3
Just follow general procedure, start in the center, alternate left, then right of center until outer bolts are reached.
I recommend 4 steps to final torque, starting with light snug down in sequence, then 1/2 torque in sequence, then full torque in sequence. final pass at full torque again, in sequence.
Old 08-21-2021   #4
Beaver's 90ZR1
Thank you very much for your help.
Old 08-21-2021   #5
Beaver's 90ZR1
Thank you very much for your help. I have another question. The reason I asked is because I have the upper plenum off putting new injectors in. So, I thought while I was in there, I should re-tighten the injector housing bolts. Is this correct? Thanks again.
Old 08-21-2021   #6
Yes,good procedure.
Same for the Crankcase Vent Cover Bolts.
Old 08-22-2021   #7
Subject to knowledgeable sources, I found a wide range of torque on my IH bolts. So, after replacing the gaskets (thank you Jerry's Gaskets), I used BLUE LOCKTITE on the threads before torquing the the IH down. On subsequent "visits" under the plenum I have not noticed ANY of the IH bolts loosening up.
And, as result, I think I can recommend the Locktite to secure the IHs (among other parts, e.g., plenum, etc.). YMMV.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 08-24-2021   #8
Ccmano
Ccmano's Avatar
If the IH bolts are loose then the lower gaskets have shrunk and hardened causing oil to be sucked into the intake. You've gone this far, go ahead and replace the lower IH gaskets as well.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
