Old 08-19-2021   #1
91vettezr1
91vettezr1's Avatar
Default headers and x-pipe
what company offers headers and x-pipe for a 91 ZR-1? I know stainless works use to but I haven't looked lately.
Thanks
91vettezr1 is offline   Reply With Quote
Old 08-20-2021   #2
rush91
Default Re: headers and x-pipe
Maybe 2?? Stainless works of course, but also OBX and the Maximizer systems. Search on Ebay for C4 ZR-1 exhaust, and you can get the OBX and Maximizer systems with straight mid pipes like Corsa has, or you can opt for a Xpipe.
rush91 is offline   Reply With Quote
Old 08-20-2021   #3
longhorns05
longhorns05's Avatar
Another option are the long tube headers made by Henderson Performance
https://www.hendersonperformance.com/hpt-parts
93 ZR-1 Red/Red 415ci
Jeal cams/headers, hf cats, B&B
Wilwood brakes, DRM coilovers
94 ZR-1 Red/Blk 368ci
SW headers, hf cats, Corsa
16 GT-R Blk/Blk Stg1 3.8
BL1200X, Shep1k, Motec
1250 whp on pump e85
longhorns05 is offline   Reply With Quote
Old 08-20-2021   #4
WantaKoth
Is there any complete bolt on systems that do not require anything special to install them in my garage.
I like the corsa exhaust and stainless works headers with high flow cats but I don?t think they bolt right up. Anyone know.
Also anyone running these Henderson?s performance? Will they bolt right up to a corsa exhaust? Thanks
WantaKoth is offline   Reply With Quote
Old 08-21-2021   #5
dredgeguy
dredgeguy's Avatar
I added Stainless Works headers with their high flow cats to my Corsa. They bolted right up.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 08-25-2021   #6
WantaKoth
Dredgeguy thanks for clarifying. For some reason I thought I had to fab a small piece between the headers and corsa. Glad to hear they bolt right up.
Old 08-30-2021   #7
Mine too (SW) and X-pipe bolt right up. But, you will have to fab a little (let's call it a "Z" bracket) for the dipstick tube to attach to after removing the stock exhaust manifolds.
When I get my workshop built, I can unpack all my tools and fab a bracket for you. OR you can look at these photos and fab up you own.
Materials:
3/4" x ~ 3/32" thick strap (from any hardware store - I recommend steel as I had issues with aluminum breaking at the 90? bends. YMMV tho.)
1/2" long x 1/4" dia STOVE BOLT with lock washer and nut.
silver paint (optional)
The length of the material (link) for the bracket is 67mm.
The length of the header tab is ~ 19mm (3/4")
The length of the middle section too is ~ 19mm (3/4")
The long tab makes up the remainder of the link.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
