I used mishimoto hoses on my 99' FRC and was impressed with quality & fit. The lettering was easily removed with acetone and some elbow grease.
I'm doing a full cooling and 134a A/C redo on my 91' this winter and am in the process of shelving parts for the process. Jerry is out of stock and the back order is TBD. Anyone fit the Mishimoto silicone hoses to an LT5? |
Another option you may have is Marc Haibeck. He should still be offering the traditional coolant hoses that look like factory pieces. That is unless you?re looking for the unique finish silicone hoses have. I?m curious about your conversion as my system is leaking and I most likely need to convert over as well this winter.
![]() Join Date: May 2010
You can find SAMCO hoses from various sources. Ref the part number in your search. http://www.2kracing.com/Product/67706.html Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() Last edited by HAWAIIZR-1; 08-17-2021 at 12:11 AM. |
![]() Join Date: Jul 2005
I use hoses from SAMCO and never had any issues.
Sam DR.Z/LT5-Performance 1990 #1822 with 383 cui |
#5 | ||
Good to hear. I'm a "do it once" kind of guy. Quote:
I'm pulling all my R12 gear out and replacing with R134a "while I'm in there". I used up all my R12 on my NCRS 91' ZR-1, I'll post up a thread of current part#'s once I can verify fit and function.n ( basically a 93-95 system). Its the evap core I'm not looking forward to. |
2kracing no longer carries samco. I called them 20 minutes ago.
I found two more vendors online, both had the ZR-1 kit listed "discontinued". These may be unobtanium now. |
#7 | |
I used the factory hose clamps to secure everything. Good luck. |
Samco hose kits are made to order. The typical time at present is around 10-12 weeks.
#9 | |
SAMCO are made in the UK. You probably have to contact one of their distributors and special order like SAM/CH ZR-1 said. Damn, a lot of parts are becoming unobtanium. I hope my set lasts until I sell the car. https://samcosport.com/product/corve...5-7ltr-v8-32v/ Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#10 | |
Hopefully Jerry is finding a source to make these in the US. Sent from my iPhone using ZR-1 Net Registry
