Old 08-11-2021   #1
Atari_Prime
Default Got the Right Parts?
I am in the process of getting my ZR-1 out of a 20 year hibernation where it largely served as a 3,500 lb. paperweight and garage ornament.
As part of that process I want to 'refresh' the various systems that may need some help. Based on symptoms that I have posted about in a few other forum locations, below is a parts list that I am planning to order. These will be installed by me and my mechanic (mostly my mechanic) and I want to make sure I get everything I need and the right parts so that we can get her roadworthy as soon as possible. Probably not going to buy some of these until needed, but want to make sure I have the right part numbers.
1994 Corvette ZR-1
Brakes (odd sticking issue when warm)
- Brake Lines (can't seem to find correct part yet). Plan is to replace the original brake lines with new ones.
- Brake Fluid - 1 qt. (Valvoline VCL 601458)
Engine (power and sometimes all throttle response disappearing in valet and full power modes)
- Serpentine Belt (old one is dried out and cracking)(Goodyear 4060805)
- Fuel Filter (GM GF652)
- Fuel Pumps x2 (Bosch 69225 or Delphi FE0114)
- Plenum Gasket (Jerry's Gaskets #10168684)
- Injectors (FIC 17109952)
How does this list look?
Are there other parts that should replace while working on some of these? Maybe vaacum sensor, a hose or two, brake pads, spark plugs?
Hoping that the above items make my car purr like a kitten?well until I get around to the stereo amps and headlight motors, and tires (only about 6 years old but still needed).
Atari_Prime is offline   Reply With Quote
Old 08-11-2021   #2
G8nightman
G8nightman's Avatar
Default Re: Got the Right Parts?
I see you are learning what it takes to sort one out I would do coils and ignition wires spark plugs check all vacuum lines cleaning under the plenum service starter test alternator clear drain plug in the valley enjoy the adventure. :-) I can add more to the list but am sure more people will comment
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 08-11-2021   #3
FYI: If & when you need these items, Jerrys Gaskets can furnish everything on your list (except for the fuel pumps which we discussed today)
- Serpentine Belt Jerry's Gaskets #10067477-G (Goodyear)
- Fuel Filter Jerry's Gaskets#25055052-M (Mahle)
- Fuel Pumps x2 Autozone/OReillys (Bosch 69225 or Delphi FE0114)
- Plenum Gasket Jerry's Gaskets #10168684
- Injectors Jerry's Gaskets #17109952 (FIC)
Old 08-11-2021   #4
Young1
Young1's Avatar
Rebuild all calipers, replace brake master cylinder, install SS brake hoses, replace clutch master and slave. If you parked it 20 years ago those are 27 years old rubber parts. And a new set of tires too. All this rubber equals safety, safety, safety. And shine up starter solenoid contacts while in there. Pull pumps out of tank. You may have to replace the entire assembly. Bringing these out of hibernation is not a simple process as you understand. Make it safe before you make it run well.
Steve Young
Second Owner
SOLD
SOLD
Old 08-11-2021   #5
Atari_Prime
Thank you Jerry, you are awesome. One question. I am reading that if I need to replace the fuel pumps, there are some clips that people recommend I upgrade to and that they are sold on your site?
Thank You.
Old 08-12-2021   #6
Thank You.
You got me on the clips. I can't think of what that might be.
Old 08-12-2021   #7
HAWAIIZR-1's Avatar
Thank You.
I am going to take a stab in the dark here that maybe you meant some stainless steel clamps that Jerry sells?
But having said that there is a plastic Y that carter200 makes a replacement billet piece you should consider while you are in there. Apparently the plastic is brittle and will eventually break and leak to lose fuel pressure etc.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 08-12-2021   #8
Atari_Prime
Attachment 15983
Correct, I referring to the clamps. A few posts had recommended adding the clamps when changing out the pumps due to the fragile nature of the plastic ones.
Old 08-12-2021   #9
Great White
Great White's Avatar
My $.02 on plug wires:
If you're not wildly concerned about originality, I highly recommend Magnecor ignition wires "while you're in there." They are hard to beat and unless you're looking close they look nearly factory. I went with their KV85 wires P/N 85161.
Great White is offline   Reply With Quote
Old 08-12-2021   #10
OK, those are worm gear, SS hose clamps. I don't stock those as they are commonly available at any local parts store.
