Old 08-03-2021   #1
wdo-mkr
Default Powdercoat
Recommendations for prep on powdercoating intake, cam covers, injector housings, throttle body, air horn?
wdo-mkr is offline   Reply With Quote
Old 08-03-2021   #2
tccrab
tccrab's Avatar
Default Re: Powdercoat
This from Cliffs Solutions pages, follow the links about halfway down the page, under PowderCoating
http://www.zr1.net/forum/showpost.ph...67&postcount=7
Word to the wise, make sure that whomever does the job really understands what surfaces can be PC'd and which cannot. If the underside of the cam covers gets coated, you are totally screwed as the cam journals are integral to cam cover.
Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 08-04-2021   #3
TX '90 ZR1
TX '90 ZR1's Avatar
Double down on Crabs comment.
Would highly recommend you get someone that has done them before to do the work.
Kenny
1990 #442
Old 08-04-2021   #4
secondchance
Lgaff- Lee - did mine in 2014. Still looks great. 👍
