Old 08-02-2021   #1
Default 90-95 Power steering pump solution
Howdy. Passing this information onto the brotherhood. Cliff please save this info. When sourcing a power steering pump for an early 90 or 91 Z a power steering pump appears the same as a standard pump on all C4s 84 up to a 91. You will see this at Ecklers and Rock auto for instance.
They are not.. The power steering pumps ARE ZR-1 specific. if you are not getting a cast iron vs aluminum body its not the right pump as the bosses and threaded portions are wrong.
So. SOLUTION?.. Volvette.com has a 90-95 Power Steering rebuilt pump part number 4PS80D there is a core charge but its is a cast iron body like the original. To the left you see the rebuilt cast iron pump. Pics 2 and 3 are the aluminum incorrect replacement next to the old pump.
BOTTOM LINE UP FRONT?.. Power Steering pumps for ZR-1s are ALL ZR-1 specific for the 90-95 model years.
GC.
File Type: jpg 99D9ED43-2C7C-4A84-A545-AD5982CFD355.jpg (77.2 KB, 50 views)
File Type: jpg 89B1FDC5-DB07-4F72-9891-5139AEABFCF4.jpg (114.9 KB, 59 views)
File Type: jpg E316F462-AF56-4B2E-8DB4-0D76D1A79F1D.jpg (205.9 KB, 59 views)
Old 08-02-2021   #2
conesare2seconds
Default Re: 90-95 Power steering pump solution
Thanks for the heads up.
Old 08-02-2021   #3
No problem..if I can save a forum brother time and effort..it is worthwhile. Even GC buys the wrong part from time to time.
The pump is buried under the motor?.. So until you are in there and you have the part in hand, it is hard to know. GC
Old 08-02-2021   #4
secondchance
GC.
GC,
Did your power steering pump fail? Any idea what caused the failure? If due to age, how many miles?
secondchance is online now   Reply With Quote
Old 08-03-2021   #5
Erik
GC.
Thanks, GC.
That's great info!
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 08-07-2021   #6
GC,
Yes it was leaking at the 154k point
Old 08-07-2021   #7
1991 Corvette ZR-1
Great information. Yep, avoid the ?Fits 1990-1995 ZR-1? from places like Corvette Central. I picked one up and had to promptly send it back. Indicated in great detail that they are carrying the wrong part. Still up for sale on their website. Not sure who is in charge of their parts supply but they aren?t familiar with ZR-1s. Just rebuilt mine like I should have in the first place.
1991 Corvette ZR-1 is offline   Reply With Quote
Old 08-07-2021   #8
It's the same all around EBay, Rockauto, autozone etc... fits ZR-1
This is why this information needs to reside HERE as the subject matter experts for the ZR-1 brotherhood. This is why this is here to SHARE....
GC
Old 08-08-2021   #9
geezer
91 CorvetteZR-1: Did you use a rebuild kit ? If so where did you source it?
geezer is offline   Reply With Quote
Old 06-08-2023   #10
Bruce Hazell
Hi. I need to replace my pump apparently and just read the post about the aluminum replacement pumps not fitting correctly. I see that Corvette Central advertises the pumps for ZR-1s now on their website. They look to me to be aluminum ones..can you advise if these would then not fit now or do you think they may have corrected the fit since 2 yrs ago when the original post was written??
Bruce Hazell is offline   Reply With Quote
