Old 07-14-2021   #1
randy ransome
randy ransome's Avatar
Default Lowering Front End
I lowered the front of my 95 ZR-1 a few years ago. I've decided it's too low. I cut the rubber on top of the Mono leaf spring. I can't remember how much I cut off. I'm hoping some one can tell me the thickness of the factory rubber that is on a stock spring.
Thanks for any help.
randy ransome is offline   Reply With Quote
Old 07-14-2021   #2
Erik
Default Re: Lowering Front End
If no one has the info, I can go and measure the spring in the garage. How low is yours now? Is it grounding a lot? I was just looking to trim mine back before installing the springs, so your input would be appreciated.
Btw, any pics?
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 07-14-2021   #3
randy ransome
My car is only 2 1/4 inches from the road up to the brackets below the radiator that are there to keep you from bottoming out the frame. Too Low.
Old 07-15-2021   #4
Erik
Agreed. That is too low!
Someone else recommended recently hacking off the rubber spacers, and they had better results then you did. I'll have to dig that up.
1990 ZR-1 # 996
