Old 07-11-2021   #1
AndiZR1
Default My 93 sputters and dies NEED HELP
Hi,
I have a n issue with my 93 ZR1.
A few weeks ago my ZR-1 started to die when she was cold and I had to keep her on RPMS to keep her running.
Now the issue is worse and she runs rougher and dies directly after starting.
Has anyone had similar problems and may knows where I should start searching for the problem?
Thanks you all!
AndiZR1 is offline   Reply With Quote
Old 07-11-2021   #2
Default Re: My 93 sputters and dies NEED HELP
Test Fuel Pump Pressure
Search "Solutions" at the top of the page where you posted this thread
Old 07-12-2021   #3
wfot
wfot's Avatar
what jerry said above
and possibly check out the idle control motor..
wfot is offline   Reply With Quote
Old 07-12-2021   #4
dredgeguy
dredgeguy's Avatar
Check to see if one of the rubber hoses disconnected from one of the fuel pumps. Pull the fuel pump assembly from the tank and check, takes less than 30 minutes. That was the problem with mine. A new stainless steel clamp fixed the problem.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 07-12-2021   #5
Stingray1967
Stingray1967's Avatar
My situation was this. Car would start up fine, run great for two minutes, and then stumble. It was the oxygen sensors.
1967 Corvette convertible, L79, 4 speed, red / black / white top
1994 Corvette ZR-1, white / black
NCRS North Central Chapter Judging Chairman
Stingray1967 is offline   Reply With Quote
Old 07-12-2021   #6
AndiZR1
Hi Guys! Thanks for your input.
I found the Problem. It was the vaccum hose that was detached from the MAP Sensor.
Old 07-12-2021   #7
Erik
May your problems always be so easy!
Congrats.
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 07-13-2021   #8
wfot
wfot's Avatar
watch out for backfires, they can pop that hose off...
FYI
Old 07-13-2021   #9
AndiZR1
FYI
Thanks... if so what do you think can cause that?
Old 07-13-2021   #10
Cause: Releasing ignition key too soon from start position.
Cure: Hold key in start position just a second longer
