Old 06-17-2021   #1
Jetjock
Jetjock's Avatar
Default Removing mufflers
How difficult is it to remove the mufflers from the car? I have a 93 Z and I wanted to clean up the mufflers and tailpipes.
Roy
Roy L. Carman
If I feel the need for speed,
I just think about flying the B-777.
1989 Dk Blue Coupe lost in divorce
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
1993 Ruby Red 40th Anniversary ZR-1 #334
1995 Black ZR-1 taken by ex-wife
2002 Pewter Coupe no idea where it is
2003 50th Anniversary Corvette #No idea what number SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Jetjock is offline   Reply With Quote
Old 06-17-2021   #2
TX '90 ZR1
TX '90 ZR1's Avatar
Default Re: Removing mufflers
Roy
Roy,
Not a big deal at all. Take the flange bolts out at the cats, undo the hangers, pull forward a bit to get out of rear muffler hangers and then drag it all out the back. This will get the whole system out in one piece from the converters back.
I've had mine out several times to do cleaning and misc. checking around.
Of course, it is a bit easier if you have a lift.
Kenny
1990 #442
Old 06-17-2021   #3
Jetjock
Jetjock's Avatar
So your talking about removing the resonator as well?
Roy
Roy L. Carman
NCM Lifetime #1468
Old 06-17-2021   #4
conesare2seconds
Just buy a couple of flange studs and plan to replace one or two when you take the exhaust off. They tend to twist off when you turn the nut.
Old 06-18-2021   #5
TX '90 ZR1
TX '90 ZR1's Avatar
Roy
Yes, everything from the cats back.
Be sure and use anti-seize when putting everything back together!
Kenny
1990 #442
