06-13-2021 | #1 |
Rough Running - Ignition Coil out?
Out driving this morning and all of a sudden the car (1991) changed character pretty severely under load. Sounded much more boomy (low frequency) and felt like it was missing. Got home and idle was shaking the whole car.
Paged through some of the forum here to get some ideas. Main suspects likely ignition or fuel. Fuel: Used Marc Haibeck's injector ohm process while still hot - nothing shorted in the primaries (a bit higher than expected, but my injectors are the yellow Bosch?). Did not check secondaries - in any case they're not active at idle. Ignition: Checked ohms across the coil pairs (plenum still on, just through the plug wire ends). 1/6, 2/3, 4/7, 5/8. All gave me 20k + ohms, except 1/6 which showed open circuit (infinity) between them. Figure we're probably going under the plenum, so off it comes (first time, not too bad!). Pulled the wires off and checked again, still open across 1/6 at the coil. Others come in at around 6k ohm. My guess is a bad 1/6 coil. Sound reasonable? Now that the plenum is off and I'm shopping at jerrysgaskets, anything else I should go ahead on while I'm here? I'm planning to do all the coils and wires at least. Might go dig for the starter solenoid contacts too...
1991 ZR-1 #1438 Black/Black & Red Last edited by KPW; 06-13-2021 at 05:57 PM. |
06-14-2021 | #2 |
Re: Rough Running - Ignition Coil out?
Replace Vacuum solenoid for secondary acuators. Standard part number VS124. Do a search plenty of info and what to do under plenum. Yes shine up the copper contacts of the starter solenoid. I use a die grinder stone in a battery drill.
07-11-2021 | #3 |
Thanks for the tips, Young1.
To wrap things up here, the car is back together and running smooth once again. Some things I noticed during this process:
I will say it's nice to have a successful plenum pull under my belt. Nice boost of confidence to understand the effort required, so that the next time it doesn't seem so daunting.
1991 ZR-1 #1438 Black/Black & Red |
07-11-2021 | #4 |
Thanks for your "follow-up" post. Always useful to others to know how a problem was solved and courteous to those who offered suggestions..
07-17-2021 | #5 | |
And, FYI, installing the gasket as you did (w/ the silicone on ONE side), I have been able to removed the plenum one or two more times w/o having to replace the gasket(s). (But, I keep some of Jerry's gaskets on hand, "just in case"!) And, kudos on the info on the condition of the stater solenoid contacts and mileage! Your experience falls right in line with a few others I have noted in my maintenance log - that is servicing likely required every 40k miles (give or take). I experienced a intermittent NO START as result of those contacts (and the bridge ring connecting the contacts) at just over 40k miles, and now (counting you) reports from 4 others experiencing either some sort of NO START or intermittent starting issues @ ~ 40k miles.
A plenum pull is "A RITE OF PASSAGE"! Welcome to the BROTHERHOOD OF THE BEAST!!
07-22-2021 | #6 |
Side Question. U say u are using yellow top BOSCH injectors on a 91 IH? Are these Bosch III injectors?
07-22-2021 | #7 |
Fair question. I?ll admit the injectors were installed prior to me owning the car, so I?m running a bit on hearsay when I say they are Bosch, also I?m not sure of what was involved in the installation.
Here?s a photo I took while the plenum was off - maybe a learning opportunity for me? Sent from my iPhone using ZR-1 Net Registry
07-22-2021 | #8 |
Its doubtful they are Bosch IIIs. They unfortunately aren?t compatible w the 90-92 IH.
07-23-2021 | #9 |
Perhaps Chevy?
https://www.southbayfuelinjectors.co...fuel-injectors
07-24-2021 | #10 | |
Tags |
coil, plenum, rough |
