Old 05-29-2021   #1
Jetjock
Jetjock's Avatar
Default Tire Pressure Sensors
I was wondering if anyone knew of a way to test the the tire pressure sensors off the wheel. Gordon showed me once that if you shake it real fast that the crystal would generate enough power to activate it if the key was on. I did do that one time and it did work. Just wondering if anybody had a different take on testing them?
FYI,They did work after I replaced the tire sensor module in the car. However, I put another set of wheels on without the sensors and left them in the original wheels. I'm sending the wheels off to be refinished so I took them off.Just wanted to see if they still worked.
Roy
Roy L. Carman
If I feel the need for speed,
I just think about flying the B-777.
1989 Dk Blue Coupe lost in divorce
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
1993 Ruby Red 40th Anniversary ZR-1 #334
1995 Black ZR-1 taken by ex-wife
2002 Pewter Coupe no idea where it is
2003 50th Anniversary Corvette #No idea what number SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Jetjock is offline   Reply With Quote
Old 05-30-2021   #2
TucsonZR1
Default Re: Tire Pressure Sensors
We used an electric vibrating sander. After removing the sand paper hold the sensor on the pad until the DIC lights up.
Old 06-01-2021   #3
Jetjock
Jetjock's Avatar
Thanks, Tom. I have one of those. I'll check it out.
Roy
Roy L. Carman
NCM Lifetime #1468
Old 06-03-2021   #4
Jetjock
Jetjock's Avatar
Tom, it worked like a charm. Initially, I thought they were bad but then I remember that it switches from service LTPWS to Low Tire Pressure. It had me going for a minute until I remembered that.
Thank you for the advice.
Roy
Roy L. Carman
NCM Lifetime #1468
