Old 05-21-2021   #1
Default If CD Player not working
Often is simply the lens needs cleaning.....
Lens Cleaner
Old 05-22-2021   #2
Default Re: If CD Player not working
I just bought the disc,hope it works.
Old 05-23-2021   #3
As you know I have several ZR-1s and each often sits for a period of time when I travel back and forth (SD-CA).
I have had three CD Players that would not play a disc when inserted (The disc would insert but not play) and all three played a CD perfectly after inserting the CD Player Lens Cleaner once or twice. I now insert the CD Player Lens cleaner in the CD Player (that will not play a CD) at least twice. I also use the CD Player Lens cleaner once in a while even if the CD Player is working perfectly.
Post 311 - CD Player Lens Cleaner
Old 05-27-2021   #4
No dice,now the cleaning CD is stuck and the CD player sounds like it's trying to eject it. Any tips on getting the CD out of the player?
Old 05-27-2021   #5
Mystic ZR-1
Mystic ZR-1's Avatar
Could be worse...
It could be your wife's favorite CD stuck in there!
Old 05-28-2021   #6
BigJohn
BigJohn's Avatar
Could be worse...
I thought we were not to talk about that!
Old 05-29-2021   #7
secondchance
Try below.
?First, turn your car off if it isn't already. While the car is off, hold the power and the eject button. Press your CD player's power and eject buttons down at the same time, holding them for about ten seconds. If your stereo has a "force eject" feature, it should spit out the CD.?
Old 05-29-2021   #8
Try below.
I was able to fish out the CD, need to get it fixed at some point.
Old 06-04-2021   #9
jss06c6
Send it to Dr. Don!
Sent from my SM-G950U using ZR-1 Net Registry mobile app
