Old 05-19-2021   #1
emorse
Default Clicking noise with ignition on
1991 ZR-1
When I turn the ignition on but don't start there is a steady clicking noise. I tried to locate source but no luck yet. It appears to continue for as long as the ignition is on. Insights?? Thanks
emorse is offline   Reply With Quote
Old 05-19-2021   #2
TX '90 ZR1
TX '90 ZR1's Avatar
Default Re: Clicking noise with ignition on
What general area is the sound coming from?
Kenny
1990 #442
Old 05-19-2021   #3
Ccmano
Ccmano's Avatar
Secondary vacuum pump?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 05-19-2021   #4
32valvesftw
Does your power antenna work? could be slipping
Maybe a plenum door in the HVAC system?
You could start pulling fuses to see if you can isolate the system.
Old 05-19-2021   #5
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Might your battery be discharged?
If below a certain voltage various things cycle on and off making such a noise.
Get your battery charged and tested, then let us know if it is still going on.
Marty
Old 05-20-2021   #6
tccrab
tccrab's Avatar
If the bushings in the headlight motors have turned to dust the motors will run continuously making an odd noise.
Try turning on the headlights, if they don't rotate, theres your smoking gun.
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
