05-10-2021 | #1 |
Power Steering Pump Pulley
While verifying my findings on a noise from a driven accessory, (In a separate thread "Water Pump Rattle?), I notice the power steering pump pulley is not running exactly true. Have not noticed before and am experiencing no issues from this. Paying such close attention to the driven accessories brought this to my attention.
I estimate it is about 1/8" from running true. Normal ? Maybe an issue? What are we doing for pumps if one is needed? I think Jerry has pulleys. Thanks for everyone's help in advance.
Kenny 1990 #442 |
05-10-2021 | #2 |
Re: Power Steering Pump Pulley
Runout by 1/8" is not normal. I would check and make sure the pump is mounted correct.
If a replacement pump (I believe power steering pump is ZR-1 specific) cannot be located, my suggestion is to have Turnone rebuild the pump. https://turnonesteering.com/ |
05-10-2021 | #3 | |
Thanks for chiming in.
Kenny 1990 #442 |
05-14-2021 | #4 |
I figured I'd back up the Turn One recommendation:
I've had some experience with a Turn One power steering pump. I can comfortably say they are one of if not the best power steering pumps on the market. I had one of their modified pumps on an '00 Z-28. It worked flawlessly, ran cool, and gave very good road feedback. |
05-14-2021 | #5 |
Has the pump been pulled before? If so, someone didn't seat the pulley all the way. It will definitely wear out the belt, which will fail eventually. Make sure you have the right pulley too.
Sent from my SM-G950U using ZR-1 Net Registry mobile app |
05-15-2021 | #6 |
Thanks for the feedback Steve.
Pump and/or pulley have not been off since I have had the car. Not sure before I got it. Will be checking out the cause next week when I have it apart for the water pump change.
Kenny 1990 #442 |
05-15-2021 | #7 | |
www.rockauto.com
05-15-2021 | #8 |
05-15-2021 | #9 | |
Thanks. I need to do a bit more checking to find the "for sure" issue. Should happen next week. Good to hear from you.
Kenny 1990 #442 |
05-15-2021 | #10 | |
The shipment from you (water pump, hoses, etc.) is scheduled to be delivered today, so will start working on it in a day or two. Appreciate all your support.
Kenny 1990 #442 |
