Old 04-14-2021   #1
Route 66
Route 66's Avatar
Default 93 Zr1 Clutch Slave Cyl
I need to replace or rebuild the clutch slave cylinder on my 93 ZR1. Looking for input from others as to what they have done. I would prefer buying American made parts if possible. Your input would be most appreciated. Thanks Ellis
Route 66 is offline   Reply With Quote
Old 04-14-2021   #2
1991 Corvette ZR-1
Default Re: 93 Zr1 Clutch Slave Cyl
Someone may be holding onto a NOS part that you could buy. Another option is to reach out to Bill Bourdeau as he used to rebuild the masters but possibly the slave as well.
http://www.zfdoc.com/
Zip Corvette has this as a replacement. Appears to be the steel version with the skinny mounting flange and not a cast iron replacement.
https://www.zip-corvette.com/91-96-c...kaAjz3EALw_wcB
1991 Corvette ZR-1 is offline   Reply With Quote
Old 04-14-2021   #3
Route 66
Route 66's Avatar
Thank you. I will contact ZFDoc
Old 04-21-2021   #4
Rock Auto carries the cast iron clutch slave cylinders you want.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
