Old 04-28-2007   #1
zr-1assassin
zr-1assassin's Avatar
Default haibeck chip install???
hey guys, got the chip the other day and want to make sure i install this correctly. disconnect the negative,open the bottom of the ecm, switch chips,replace ecm and connect the neg cable back and done! is this correct??? any tips? thanks
zr-1assassin is offline   Reply With Quote
Old 04-28-2007   #2
Aurora40
Aurora40's Avatar
Default Re: haibeck chip install???
Yup, that's pretty much it. There are clips of sorts on the sides of the PROM that hold it in. Just push then to the side and the chip will lift out a little. Push them back towards the PROM when you put the new one in. If you've ever added memory to a computer, it's similar to that. It's very easy.
Old 04-29-2007   #3
zr-1assassin
thanks.....got it done
Old 05-05-2007   #4
Hammer
Hammer's Avatar
Talking Re: haibeck chip install???
How do you like it so far?
Old 05-05-2007   #5
zr-1assassin
i do notice a difference in idle and it seems to get to 7000 a little faster. all in all i do notice a change
Old 06-12-2007   #6
mrzzzr1
mrzzzr1's Avatar
What performance profile did you have it programed to?
mrzzzr1 is offline   Reply With Quote
Old 06-12-2007   #7
zr-1assassin
just the entry level chip, all the little things it does. mark could tell you a lot better than i
Old 06-12-2007   #8
Hammer
Hammer's Avatar
Standard for me too.
