Old 04-28-2007   #1
Hammer
Hammer's Avatar
Talking SAMCO HOSE INSTALL
For those that are about ready to install their Samco hoses, I have a tip for you. GET SOME DIELECTRIC GREASE. Put just a little bit on the inside of the hose before you try to put them on. I fought installing the hose on the water pump last night and finally gave up. First thing this morning I used the grease and that puppy slipped right over the outlet on the pump.
I am using the clamps from the Registry and they are slick. I tightened them up by hand as tight as would be prudent and then gave them about a 1/4 of a turn with a ratchet. They really shouldn't come loose.
Old 04-28-2007   #2
Aurora40
Aurora40's Avatar
Default Re: SAMCO HOSE INSTALL
I did that too. Those things are a real bugger to get on!
Old 05-01-2007   #3
cuisinartvette
Fortunately mine went on pretty easy, just lubed them a slight amount. Now they come back off for some proper clamps.
