01-08-2021 | #1 |
Service parts identification sticker
My center console at some point was removed and replaced and the sticker is no longer present. I asked several outfits including corvette museum for replacements and unfortunately no one can reproduce them. Has anyone tried to reproduce them, size, font style? anyone have a template in word that I can use. I can recreate them but it will take a ton of time to match font style and spacing but I was wondering if anyone on here has had this issue and how did you go about replacing it??
attached is my build sheet. thanks Anthony |
01-30-2021 | #2 |
Re: Service parts identification sticker
To have it judged you really dont need it. The NCRS requires a copy of the Build Sheet be sent to the Team Leader from the Museum. It will when given to you when your car is Judged.
05-11-2021 | #3 |
I spent many hours reproducing these SPI code stickers. I could not find anyone to redo these when you don't have the originals so I did them my self. I redid the air bag and RPO sticker, if anyone needs a set I would need their RPO codes and I can reproduce them for you.
What do you think? they look pretty good compared to the originals. |
05-11-2021 | #4 |
Be careful. If the car goes to a major auction and is found to be reproduced, the car can be confiscated. Having the build sheet is all that is needed especially on a ZR1 that has all RPOs already.
Its like reproducing a C2 Trim Tag. |
05-11-2021 | #5 |
I have the build sheet also, I just wanted to have the stickers too.
05-11-2021 | #6 |
See PM I just sent you.
Joel Tampa/Rockledge, FL Present Collection 1969 350/300 AC Convertible 1972 454 Coupe 2nd Owner 1988 KOH EX5006 - ZR-1 Prototype 1990 ZR-1 #277 NCRS Dave McLellan Award 2019 1994 Copper Convertible NCRS Dave Hill Award 2012 2001 Z06 122k miles |
05-11-2021 | #7 |
I think you will be fine since you have the broadcast sheet too. Nice job with the reproduction.
07-12-2022 | #8 |
nice job with the reproduction parts label. Can you do one for me ?
07-12-2022 | #9 |
Well done Anthony, nice to know we have your talents in the group!
07-12-2022 | #10 | |
If you go to this site www.compnine.com and create a login you can get all of your RPO codes via your VIN. From there I can then create one for you. I will send you a PDF of the label then you will have to print it on a sticky back sheet of paper, cut it out carefully and then your good to go. let me know Anthony |
